Re: S M Live pump
Posted by Les Repair on April 26, 2001 at 18:08:45 from (206.28.174.43):
In Reply to: S M Live pump posted by Doug A on April 26, 2001 at 05:47:19:
Blowing out the seal is a pretty good indication the pump is getting bad. If you get lucky cross reference the seal number and replace it. This can be done without dismantaling the pump by using a very small chisel and prying out the seal. GOOD LUCK
Post A Followup
: Re: Re: S M Live pump
