Re: IH A clutch question
Posted by Dave T on April 26, 2001 at 18:27:02 from (63.20.49.31):
In Reply to: IH A clutch question posted by John S on April 26, 2001 at 13:27:25:
Your sudden clutch problems may be caused by the leaking coolant out of your old frost plug. Take off the pressure plate and check every thing out. If your graphit throw out bearing has minimal wear, and still goes around, then I wouldn't replace it. The replacement one for my Super C was over $130, unless you want to.. Be sure to replace the pilot bearing, they are cheap ($7.00 or so) I used one of these 3M "Paint and Rust Remover" wheels. They work really slick. Just put it in your drill and clean your disk, pressure plate and flywheel, then clean it off real good with brake cleaner.....but off course if you clutch is shot, then it's shot and needs to be replace.....just check it out....oh,and thanks for the compliment.....Dave
Post A Followup
: Re: Re: IH A clutch question
