Re: Farmall BN timing brakes
Posted by gene b on April 27, 2001 at 04:36:06 from (63.25.166.45):
In Reply to: Farmall BN timing brakes posted by Paul from Michigan on April 26, 2001 at 20:21:28:
there is no timing of a mag you are in time or it would not run sounds like a weak starter or bad cables should be #1ga ground at the trans cover positive grnd might need a rebuilt starter they realy can make a difference you are right on the brake rod probably busted at the band not to hard a cherry picker would be nice to remove the housing
Post A Followup
: Re: Re: Farmall BN timing brakes
