Re: Super A Draining Hydraulic Cylinder
Posted by Haas on April 27, 2001 at 05:09:42 from (129.37.117.110):
In Reply to: Super A Draining Hydraulic Cylinder posted by Tyler (MD) on April 26, 2001 at 17:01:05:
I assume you are talking about the touch control unit. It has no vent, so there is frequently some pressure in there. Take out the fill plug first. There should be nothing there but air. Remove slowly and let the pressure vent. Then you can remove the drain plug.
Post A Followup
: Re: Re: Super A Draining Hydraulic Cylinder
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
