Re: 460 problems
Posted by dick on April 27, 2001 at 13:31:33 from (63.120.111.98):
In Reply to: 460 problems posted by Adam on April 27, 2001 at 12:26:21:
I'm not sure if it's true on the 460, but some IH tractors' hydraulic valves are designed to latch in the up or down position, and then are supposed to unlatch when the cylinder reaches the end of its travel. If the hydraulic system has problems (not putting out as high pressure as it's supposed to), the valves don't unlatch. It may be that's what's happening to you?? Are your hydraulic valve handles in the middle (unlatched and inactive) position when you're having this problem?
Post A Followup
: Re: Re: 460 problems
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
