Re: Right carburetor for M
Posted by The Red on April 28, 2001 at 04:34:48 from (12.75.196.168):
In Reply to: Right carburetor for M posted by Oregon Kid on April 27, 2001 at 22:11:19:
Sometimes these can get confusing. The two fuel bowl numbers are
6514 for distillate or kerosene.
8731 for gasoline only.
The throttle body (upper piece with the throttle plate in it) is 8867 in the parts book I have.
I think the NAPA listing of the 6513 for the fuel bowl would be the correct kit for your carburetor. The difference in the two kits would probably be the diameter size of the fuel screw adjusting seat. There are several different sized seats for distillate/gasoline, stock gasoline only and performance added gasoline.
Do you have the gasoline/distillate manifold?
Post A Followup
: Re: Re: Right carburetor for M
