Re: H Belt Pulley Diagram
Posted by michael Soldan on April 28, 2001 at 22:28:40 from (216.46.140.186):
In Reply to: H Belt Pulley Diagram posted by 1PWRFULH on April 28, 2001 at 14:33:41:
I did the pulley on my H last fall. I was able to change the bearings and the seal on the bench. I must be getting old because I can't remember the details. My I-H dealer told me how to take it apart. After you have it out of the tractor set it on the bench with the drive gear up. You remove the two capscrews(bolts) and the shaft separates. You should be able to tap on the bearing and move it off. I put the new bearing in by tapping on it with a piece of hardwood. Then the seal went on in the same manner using a piece of wood to gently get it in place. Slide the shaft back into place and replace the capscrews. Haas suggests you need a press to get the bearing in and that would be easy but I managed the hard way and it wasn't too bad a job. My problem is the setting of the teeth to mesh. The roller assembly has 3 shims and the end of the roller drive has 3 shims. I need to have the tractor running and pumping oil up to the pulley before I know what kind of job I did. I had pulley noise when I turned it by hand but it may not be there when the oil is being pumped. I do know I needed a new seal anyway and when it was apart ..you may as well put the bearing in. all available from your I-H dealer. Good Luck from Mike Soldan in Exeter Ontario
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
