Re: Re: H Belt Pulley Diagram
Posted by Michael Soldan on April 29, 2001 at 08:08:08 from (216.46.140.186):
In Reply to: Re: H Belt Pulley Diagram posted by The Red on April 29, 2001 at 05:36:03:
Red, this raises a question about pulley lubrication. I understand theres a thrower gear below that is supposed to throw oil up into the pulley housing. I just filled this H with 6 gallons of gear oil and didn't add any to the pulley reservoir. It looks like you could get 3 or 4 quarts in it..would that be over filling the tractor? I think all I need do is run the tractor down the road a half mile and clutch and engage the roller and it will fill itself. ...just a question re could you over-fill? Once the reservoir fills itself it should stay full unless you have a bad seal..correct? Thanks Mike in Exeter Ontario
Post A Followup
: Re: Re: Re: H Belt Pulley Diagram
