Re: 140 Pesco Pump Replacement
Posted by hendrik on April 29, 2001 at 23:07:17 from (62.100.15.226):
In Reply to: 140 Pesco Pump Replacement posted by Bob on April 29, 2001 at 19:48:18:
Gene B says that if the seal leaks because of a worn shaft, place a speedy sleeve on the shaft and put in a new seal. This will fix the leak. If it appears to be necessary for my Super A pump I will certainly try. You buy speedy sleeves in a good bearing shop. They cost their weight in gold; for the pump shaft aprox. 20 dollars.
Good luck. Hendrik.
Post A Followup
: Re: Re: 140 Pesco Pump Replacement
