Re: Re: Re: h voltage regulator
Posted by gene b on April 30, 2001 at 03:23:38 from (63.15.134.191):
In Reply to: Re: Re: h voltage regulator posted by jakob on April 29, 2001 at 18:35:57:
ground the FIELD and if it charges the bad one is the regulator if it doesnt charge then it is the generator you can run with the field grounded now I am talking about grounding the FIELD term on the generator make sure you find the no of the generator so you can get the right reg after all these years hard to tell what you have
Post A Followup
: Re: Re: Re: Re: h voltage regulator
