Farmall M Rim Repair - HELP!
Posted by Bama Red on May 01, 2001 at 05:44:26 from (206.166.230.31):
I've got a 10 x 38 rim which is rusted out by the valve stem (not unusual, I understand). I want to remove the tire, cut out the weak metal and weld a plate in place from the inside and then drill a new hole for a valve stem. Is this a realistic repair? Has anyone done this type of repair. Several of the farmers in my area say it can be done. I haven't been able to find a used rim and can't afford a new one.
Post A Followup
: Re: Farmall M Rim Repair - HELP!
