Farmall Tractors Discussion Board
Re: NEED A GOOD SMALL ROW-CROP TRACTOR
Posted by John Healey on February 09, 1999 at 17:15:02:
In Reply to: NEED A GOOD SMALL ROW-CROP TRACTOR posted by HUB on February 09, 1999 at 10:36:15:
HUB, I own three Cubs and it IS a fine little tractor specificly designed for cultivating and built approximately 2/3 the size of the A. A Cub will do the job , but a Super A ,100,130,or 140 will do it easier. The Super A is the tractor of choice of asparagus growers in California.It can be loaded down to twice its weight for planting and holds up to the load . The Super A has more ground clearance and twice the power. I'd go with the Super A,100,130,or 140. Stay away fron the A unless you don't mind a manual lift ( a pneumatic lift on the A is so so if it even works ). If you want a copy of an article on using the Super A for growing asparagus send your mailing address, I'll mail a copy. Good luck. John
Post a Followup
: Re: Re: NEED A GOOD SMALL ROW-CROP TRACTOR
