Re: Super A New Style Throw Out Bearing
Posted by Bob/Maine on May 02, 2001 at 03:58:56 from (216.34.56.12):
In Reply to: Super A New Style Throw Out Bearing posted by Tyler (MD) on May 01, 2001 at 17:50:01:
Tyler, the only thing that the throw-out bearing does is to place pressure on the fingers of the pressure plate. Once it does that, the hole unit turns. That bearing isn't turning in that race. Make sure and carefully check the rest of the parts, the pressure plate, and the clutch plate that is attached to the fly-wheel. My clutch plate was warped badly and needed grinding flat. Bob
Post A Followup
: Re: Re: Super A New Style Throw Out Bearing
