Re: 400 is Whining
Posted by John In Iowa on May 02, 2001 at 10:37:51 from (199.108.164.33):
In Reply to: 400 is Whining posted by Justin Kuck on May 02, 2001 at 09:47:54:
Justin,
The whining in the PTO unit is the sun gears that is turning in the unit or a pilot bearing in the unit. You may want to check the bands adjustment and it may help to change the oil in it. Use Hy-Tran. Also there is a seasonal disconnect under the TA unit. It saves a lot of wear and tear on the PTO unit if you shut it off when you are not using it.
John In Iowa
Post A Followup
: Re: Re: 400 is Whining
