Re: cub steering bushing removal
Posted by John (63 Cub, NC) on May 02, 2001 at 11:23:50 from (152.34.242.90):
In Reply to: cub steering bushing removal posted by Gary on April 30, 2001 at 10:18:31:
I have not tried this myself, but I have heard the following technique can be successful. Measure the inner diameter of the bushing and find a steel rod of such a diamter that it just slips in the bore. First, pack the bushing bore full of axle/bearing grease with your fingers. Insert the rod end and wrap a rag or towel around the rod next to the bushing. Give the top of the rod a good whack with a 2-3 lb hammer. The hydraulic pressure created may drive it out. If you do not use a rag , you and your shop will be splattered with grease. Good luck!
John
Post A Followup
: Re: Re: cub steering bushing removal
