Re: F-20 With Liftall belly pump
Posted by Dick (IL) on May 02, 2001 at 15:03:13 from (205.188.193.33):
In Reply to: F-20 With Liftall belly pump posted by SuperCmore on May 02, 2001 at 08:31:47:
Interestingly enough, optional hydraulics are not listed in the F-20 parts catalog as they are for the hydraulic lift used on the F-14. Perhaps there was a seperate package available from IHC, similar to the F-20 mechanical lift option which is also not listed in the master parts catalog.
Post A Followup
: Re: Re: F-20 With Liftall belly pump
