Re: How does one remove sleeves?
Posted by Dan on May 02, 2001 at 18:47:27 from (12.18.158.25):
In Reply to: How does one remove sleeves? posted by mk on May 02, 2001 at 18:18:31:
When I pulled the sleeves on my SMTA I made a "slug" out of 1/2 inch steel, round, that would just fit inside the hole in the block, I drilled a hole in the center and used a ready rod through it. I used channel iron on the top and 2 other pieces of ready rod to hold it over the cylinder. not hard or expensivbe to make a usable puller. I don't know if the sleeves on the cub are wet or dry, if wet sleeves they should pull easier than the dry ones I did.
Post A Followup
: Re: Re: How does one remove sleeves?
