Re: How does one remove sleeves?
Posted by gene b on May 02, 2001 at 18:59:45 from (63.42.174.114):
In Reply to: How does one remove sleeves? posted by mk on May 02, 2001 at 18:18:31:
why dont you rent one those are wet sleeves can be pretty tough to pull might want to take the block to someone who can press them out you will want to have the block boiled any way you will be surprized at the residue at the bottom of the sleeve check around for prices I have made one as I pull lots of them they should not charge very much maybe 50 to pull and boil the block wire the bushing fast that the gov assy turns in so it wont get loose and fall out
Post A Followup
: Re: Re: How does one remove sleeves?
