Re: Super A Rockford Clutch Fingers
Posted by David A on May 03, 2001 at 05:46:55 from (12.26.113.3):
In Reply to: Super A Rockford Clutch Fingers posted by Tyler (MD) on May 03, 2001 at 03:37:32:
Before you put it back together, I'd put a LITTLE grease on the clutch disk shaft splines (not so much that it will fly off). This should help the disk "center" for less drag against the moving parts when the clutch is depressed. Other comments?
That clutch finger difference does not seem good to me. May not have smooth operation. Others?
Post A Followup
: Re: Re: Super A Rockford Clutch Fingers
