Re: How does one remove sleeves?
Posted by TMAC on May 03, 2001 at 06:14:10 from (207.144.246.142):
In Reply to: How does one remove sleeves? posted by mk on May 02, 2001 at 18:18:31:
I just yesterday pulled sleeves out of a F30 with a semi-homemade puller. You need to get a machine shop to make the round plate to fit the bottom of the sleeve. While they are at it get them to make a thick steel bar(1" thick by 3" wide at least)a foot long and a hole in the middle big enough for a 3/4" threaded rod and get a couple of bars of steel that stand about 4" high. That should be high enough to pull wet sleeves. Buy the threaded rod from NAPA and make sure its at least a grade 5 and two grade 5 nuts with one lock washer and flat washer. The NAPA stuff is about $10. The shop stuff shouldn't be much more. To be even cheaper, look around for scrap that will work on the top end.
Post A Followup
: Re: Re: How does one remove sleeves?
