Re: Removing Pilot Bearing From F30?
Posted by Regularman on May 03, 2001 at 09:50:45 from (38.154.4.21):
In Reply to: Removing Pilot Bearing From F30? posted by TMAC on May 02, 2001 at 17:35:03:
The bearing can be pulled out. It will be tight, they are a pressed fit. If your good with a torch you can split the race and it will fall right out. You don't need to remove the nut.
Post A Followup
: Re: Re: Removing Pilot Bearing From F30?
