Re: Farmall A Zenith Carb
Posted by Robertn on May 03, 2001 at 12:27:44 from (132.233.247.6):
In Reply to: Farmall A Zenith Carb posted by Kurt Christensen on May 02, 2001 at 21:27:35:
I had an odd carb on my A. I went ahead and got a proper carb. Mine had too wide of mounting stud spacing. One stud had been removed, and a skinnier bolt put in its place. The carb had worked, but I wanted a correct one.
These carbs and minor variations were used on a lot of tractors. Maybe you have one from a different tractor, that just happened to be close and fit???
Post A Followup
: Re: Re: Farmall A Zenith Carb
