Farmall Tractors Discussion Board
Re: Setting the timing on an H
Posted by mjdelaney on February 10, 1999 at 04:39:32:
In Reply to: Setting the timing on an H posted by Brian Miller on February 08, 1999 at 09:14:50:
I thought you would have quite a few hits on this. I see there are still none. I have an IH blue ribbon service manual that mentions that each helical spur gear in the drive train is punched. I assume you just align the marks. Your dealer must have a shop manual that goes into details on this. I have a 50 "H". Twenty years ago, I did the motor over. I didn't touch the mains. I work this tractor pretty hard. It still has great oil pressure and I've never had the crank out. Let us know how you make out.
Post a Followup
: Re: Re: Setting the timing on an H
