Re: Wide Axle Adjustment (Super A)
Posted by David A on May 04, 2001 at 05:59:50 from (12.26.113.3):
In Reply to: Wide Axle Adjustment (Super A) posted by Tyler (MD) on May 04, 2001 at 03:12:56:
Tyler, I use a 5' mower and am currently running the front axle out in the third notch. It does run over some uncut grass but it does seem to matter. The right front wheel running just on the cut grass provides a perfect guide for the next lap. I learned all I know about adjusting the axle from Haas. My biggest problem was a bent tie rod. Had to have a shop press it free. I took both tie rods off. Then I jacked up one front wheel at a time under the axle, removed the wheel/hub at the wheel bearings then loosened the axle clamps. I then sat on the floor and kicked on the king pin until the axle started to rotate. Then worked the axle completely out, cleaned and greased, and reassembled at the desired width. Also a good time to grease the front wheel bearings. If the axle won't move, others suggested roping a 2x4 to the king pin to add leverage. One reason I set mine pretty wide was for added stability. Then I realized that because of the front axle pivot, the front axle does not provide stability. Duh.... Stability is totaly determined by rear width and weights.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
