Re: Grinding gears
Posted by Bob M on May 04, 2001 at 06:29:09 from (192.232.119.194):
In Reply to: Grinding gears posted by Rob in Wis. on May 04, 2001 at 06:18:41:
Rob - grinding gears could be 2 things:
1 - You're not waiting long enough for the gears to stop turning after you depress the clutch. Good procedure is to step on the clutch, wait 5 or 6 seconds for everything to stop turning, THEN move the shift lever into gear.
2 - Clutch is out of adjustment - it's not fully releasing when the pedal is depressed.
Can't help on the cultivator question...
Post A Followup
: Re: Re: Grinding gears
