Re: Tranny lube???
Posted by Knut on May 04, 2001 at 06:33:56 from (209.240.249.12):
In Reply to: Tranny lube??? posted by Paul on May 03, 2001 at 19:04:33:
From 1958 on most Farmall/International tractors
used Hy-tran fluid for hydraulic -differential
fluid. Use it or oil supplier equivalent. This
fluid contains moisture absorbent additive so if
you use tractor in below freezing conditions it
needs to be completely changed more often to get
rid of the moisture it absorbs. Change hydraulic
filter(s) at same time
Post A Followup
: Re: Re: Tranny lube???
