Re: Re: Installing Alternator on my H
Posted by Zonie on May 04, 2001 at 06:59:31 from (152.163.206.207):
In Reply to: Re: Installing Alternator on my H posted by Bob M on May 02, 2001 at 04:48:41:
Thanks for the help. Your memory is right, I did get it wired. and functioning properly. It's nice to have a charging system that works.
For now, I have the alternator IG wire wired thru my light/ charge switch. My tractor has the magnito and the on off switch only grounds the mag out to kill the ignition, so I could not use that switch I just have to remember to turn the light switch on for it to charge and to shut it off when I'm done.
I guess I'll wire in a 2 pole relay to kill the alternator and ground out the mag at the same time since my memory isn't so good these days.
Post A Followup
: Re: Re: Re: Installing Alternator on my H
