Re: McCormick Deering 1020
Posted by Bill Smith on May 04, 2001 at 15:43:28 from (128.242.4.59):
In Reply to: McCormick Deering 1020 posted by bryan on May 02, 2001 at 18:12:03:
I have never worked on 10 20 but I would guess they would come out the bottom. If the piston won't fit through the crankshaft push piston down far enough to get connecting rod lose and then push the piston itself out the top.
Post A Followup
: Re: Re: McCormick Deering 1020
