Re: Re: Re: HELP, The Farmall C I purchased a couple months ago OVERHEATS
Posted by Haas on May 06, 2001 at 19:33:28 from (64.12.105.34):
In Reply to: Re: Re: HELP, The Farmall C I purchased a couple months ago OVERHEATS posted by Kurt Thomas on May 06, 2001 at 07:17:43:
If you have no water pump, there should not be a thermostat. If your system is clean, you do not need the water pump. I suspect your radiator is stopped up. Get all the stuff off the outside of the fins. If they are clean, take the radiator off and have it boiled out. While you have it off flush out the block.
Post A Followup
: Re: Re: Re: Re: HELP, The Farmall C I purchased a couple months ago OVERHEATS
