Re: stuck engine m-farmall
Posted by Larry Ks on May 08, 2001 at 00:23:21 from (205.171.70.157):
In Reply to: stuck engine m-farmall posted by john on May 07, 2001 at 18:47:23:
If you're relatively sure there hasn't been any water getting into the engine, I'd sure give it a good trying before I tore into it...this just might be the one you can get unstuck and have run decent. I've tried everything from brake fluid, to pb blaster, to liquid wrench, kroil (spray), I wonder if you'd simply use diesel fuel, and let it set a week or so, and then jack up a wheel, and then put some weight on it one direction, and then a day or two later put the weight the opposite way....what I'm trying to say is this...take your time, and you might just be lucky...
Post A Followup
: Re: Re: stuck engine m-farmall
