Re: Re: Re: '46 Farmall M Brakes Installation??
Posted by The Red on May 08, 2001 at 10:18:29 from (206.246.187.2):
In Reply to: Re: Re: '46 Farmall M Brakes Installation?? posted by Tis on May 08, 2001 at 09:19:56:
Tis plan on pulling the brake drums and replacing those bull cage seals as they are called. The original seal is a thick assembly with two seals built in. You will want to put in two new thin seals on each side. I have replaced quite a few seals over the last 10 years on several Hs. Have safety glasses handy. Drill two 3/8 inch holes as close as you can into the seal facing towards the outer edge. The drill bit will go about 1 inch then you will notice it will stop against the seal cage casting. Then pound a chisel into the two holes. I then hit the side of the chisel with the hammer using the outer casting as a fulcrum. When the seal starts prying out at the chisel, I use offset plyers and pry it out. It will more than likely come out in pieces. You can stick the two new seals in as far as you want. You will have some extra depth to play with. If the inner part of the drum, where it rotates in the seal is rough, try to set the seals to avoid the roughest portion. Hope this is somewhat clear!
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
