Re: Farmal C Compression
Posted by Bama Binder on May 08, 2001 at 13:26:36 from (206.5.110.200):
In Reply to: Farmal C Compression posted by Kent VanTimmeren on May 08, 2001 at 07:59:48:
Each cylinder should be within 10% of eachother. So if you have readings between say 90 and 100, you are OK. If I remember correctly, the C should have a 6:1 ratio, so 110-120 would be right. The repair manual will give you the factory specs.
While making a determinaation as to the health of an engine based on compression is not an absolute, the actual test and the correct factory specs ARE absolute.
Post A Followup
: Re: Re: Farmal C Compression
