What Weight or Type of Gear Oil To Use ???
Posted by Fatback on May 09, 2001 at 03:31:18 from (208.136.78.20):
Removed the "Homemade" wide front end on the "C" and installed the orignal narrow front.
Discovered that the steering box is dry.
What weight or type of gear oil should I install?
Post A Followup
: Re: What Weight or Type of Gear Oil To Use ???
