Re: To tilt or not to tilt????
Posted by haas on May 09, 2001 at 06:43:13 from (205.188.193.187):
In Reply to: To tilt or not to tilt???? posted by Havin Fun in Mo on May 08, 2001 at 19:01:17:
If you are just going to plow snow and grade your driveway, you don't need tilt. If you are going to make ditches with it you will need the tilt. Generally you get a little more for your money than just the tilt feature. The ones that tilt are usually a heavy duty blade. I have a blade that is sort of in between. You can tilt it by changing bolts that attach the blade to the frame. Not so convenient, but will do the job. I've never used the feature though.
Post A Followup
: Re: Re: To tilt or not to tilt????
