Re: 48 Cub Good oil preasure for 10-15 Minutes
Posted by p on May 10, 2001 at 10:44:32 from (12.33.190.5):
In Reply to: 48 Cub Good oil preasure for 10-15 Minutes posted by Keith L. on May 10, 2001 at 04:02:34:
I have a 52 Cub that did this. I found out that my bearings were shot. I would say you might have this problem. Also, there is a spring and plug that is supposed to regulat the oil pressure, you may want to pull it out and see if it is cracked or something, but I would doubt it. I would bet that it is your bearings. As soon as the motor warms up the tolerances increase and the oil has not resistance. Mine would drop to idle and the thickness of the oil made no difference. My dad refused to let me tear it apart until after mowing season and therefore we had a really expensive rebuild ahead of us.(ground crank, bored block, new pistons etc.) be careful. and find the problem, it wil not just go away.
I would also pull the pan and do a visual check.
Post A Followup
: Re: Re: 48 Cub Good oil preasure for 10-15 Minutes
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
