Re: 300Utility runs, quits, then runs fine
Posted by Charlie on May 10, 2001 at 14:25:14 from (209.130.148.234):
In Reply to: 300Utility runs, quits, then runs fine posted by Dr. JK on May 10, 2001 at 13:45:52:
I had a similar problem with mine although mine wouldn't always restart and run for a long time. On mine I found there was a lot of crude in the tank and the end of the sediment bowl assembly that goes inside of the tank had rusted away enough it was no longer sticking up above the bottom. Thus it allowed any junk floating along the bottom to get into the opening and plug it up. I stuck about 1 inch of copper tubing inside of the fitting making the inlet about 1 inch above the bottom and I didn't have another problem.
Post A Followup
: Re: Re: 300Utility runs, quits, then runs fine
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
