Farmall 560 Hydraulics Low Pressure
Posted by Butch on May 10, 2001 at 21:43:08 from (172.142.199.140):
Need help with a 1963 Farmall 560. No hydraulic pressure at idle. 310 psi at 2000 rpm. Water was in trans oil. drained out and re-filled. Cleaned
hydraulic filter. Still same problem. Could the problem be the pump or a check valve? is the pump hard to change? Can the relief valve be checked from outside the tractor? Any suggestions. Thanks much. Butch.
Post A Followup
: Re: Farmall 560 Hydraulics Low Pressure
