Re: timing
Posted by Haas on May 11, 2001 at 06:32:16 from (205.188.196.49):
In Reply to: timing posted by skeeze on May 11, 2001 at 03:20:33:
Should not be running at 240 degrees. Make sure your radiator fins are clean. Your radiator needs to be taken off and sent to the shop to be boiled out. While you have it off, take off the fittings that are bolted to the block to which the hoses attach. Then flush as much of the crud out of the block as you can.
Post A Followup
: Re: Re: timing
