Re: A Final Drive Removal
Posted by Dave G on May 11, 2001 at 21:05:40 from (158.252.165.253):
In Reply to: A Final Drive Removal posted by Dave U on May 08, 2001 at 07:14:31:
I have done a couple of B's. Like David A said- be sure to check both seals for the shaft (one at transmission and one at final housing). Make sure you check the shaft for wear marks from the old seal. If the shaft has grooves wore in it the new seal might not seal very good. Some people say you can try JB weld to fill in the wear grooves.
Post A Followup
: Re: Re: A Final Drive Removal
