Re: Farmall M hydraulics
Posted by Bob (WI) on May 12, 2001 at 06:22:15 from (209.94.172.38):
In Reply to: Farmall M hydraulics posted by Whitepark on May 11, 2001 at 20:16:26:
The lift all is a one way system, the outlets are all pressure, the second outlet on the left side has a delayed reaction for raising the mounted rear cultivators after the front cultivators are raised at the end of the row, run your return line from the down pressure side of the hyd. cylinder right into the Hyd. resevoir filler hole, you will not have down pressure but will be able to raise the chisel plow. That's the way I remember it.
Post A Followup
: Re: Re: Farmall M hydraulics
