Re: Re: Re: Re: Re: SMTA TA Clutch
Posted by John In Iowa on May 12, 2001 at 06:39:10 from (199.108.164.30):
In Reply to: Re: Re: Re: Re: SMTA TA Clutch posted by Ace Schrunk on May 11, 2001 at 19:41:08:
Ace,
I had the TA clutch come apart this winter when I had the disturber drive come apart and the engine had a big back fire. The engine was running at a high idle and the TA was in the high side. I had just pulled up to the shop and had gotten off to open the shop door when this happen. Like I said when you turn the TA backwards in the high side it locks up and brings everything to a halt. In my case it torn the TA clutch apart. I put in a new rebuild TA clutch, pressure plate, Main clutch, pressure plate, new throw out bearing in both, all new bearing in the TA and a rebuild over running clutch in the TA. Including the new oil the Bill was just under $800.
John In Iowa
Post A Followup
: Re: Re: Re: Re: Re: Re: SMTA TA Clutch
