Re: Re: Re: Re: Belly mower or pull behind?
Posted by kenny christopherson-read.. again on May 12, 2001 at 17:39:03 from (205.188.195.33):
In Reply to: Re: Re: Re: Belly mower or pull behind? posted by TAKE OFF THE CAPS on May 11, 2001 at 18:12:29:
well, i have a front blade.. loko in the photos, and you can see it, look under kenny christopherson. it doesnt push snow well cause of the runners- it doesnt scrape, and it seems like it floats on fluffy snow-works better on wet snow. I also just re-wired the electrical, becuase sometimes it charges, and sometimes it doesn't.. and now its the same thing. when it is at full throttle, it discharges then at idle. does anyone know this problem? it is 12V, and the heat resistor above the distributor is cracked. would this make a difference? i did clean out the distriubutor cap, and points.. thanks agian
Post A Followup
: Re: Re: Re: Re: Re: Belly mower or pull behind?
