Re: Glowing in the dark
Posted by Bob M....that's normal on May 12, 2001 at 19:34:52 from (66.66.72.246):
In Reply to: Glowing in the dark posted by Havin Fun in Mo on May 12, 2001 at 19:16:11:
Keep havin' fun! A flame out the exhaust and glowing manifold/muffler are normal under full RPM/full load operation. Means only you've got a well-tuned engine that's working hard!
Just keep an eye on the water temperature, and let the motor run with no load at about 1/4 throttle for a couple minutes to cool before shutting it down.
Post A Followup
: Re: Re: Glowing in the dark
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
