Re: Super C, hydraulics
Posted by gene b on May 13, 2001 at 19:39:01 from (63.25.167.29):
In Reply to: Super C, hydraulics posted by Rod Uhl on May 13, 2001 at 12:41:38:
better take out the screw on top of the pump and fill with oil turn over engine a little and refil this is the easiest way to prime the pump you will hear the pump working and the pressure side will get warm then work the levers back and forth to get the air out of the system
Post A Followup
: Re: Re: Super C, hydraulics
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
