Re: HELP no lift on three point hitch
Posted by KURT on May 14, 2001 at 04:15:41 from (64.109.118.246):
In Reply to: HELP no lift on three point hitch posted by budaa on May 13, 2001 at 16:06:07:
You need to find out what the pressure
is in the hydraulic system. I think those
are about 2" bore cylinders. A 2" bore
will have a total area of 3.14 square inches.
Then you will have to find out the force
generated take the pressure on the gauge
and multiply it by 3.14. If you
have 600 psi then you will have 1884 lbs.
per cylinder to lift. You may have to
adjust the relief valve or you could have
an internal pressure leak.
Post A Followup
: Re: Re: HELP no lift on three point hitch
