Re: 300 Utility Steering overhaul?
Posted by JohnIH on May 14, 2001 at 05:22:59 from (208.169.39.71):
In Reply to: 300 Utility Steering overhaul? posted by Jeff on May 13, 2001 at 17:47:37:
Jeff,
If you are referring to the steering gear box where the worm gear is located, I had the same problem with leaking. The cheapest solution is to drain the gearbox and pack it with gun grease. This makes the steering a bit tighter and ends the leaking problem. The turning of the gearbox is so slow that grease is sufficient.
JohnIH
Post A Followup
: Re: Re: 300 Utility Steering overhaul?
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
