Re: Has anyone ever converted a C over to a water pump??
Posted by Stan(VA). on May 14, 2001 at 06:02:57 from (216.164.142.27):
In Reply to: Has anyone ever converted a C over to a water pump?? posted by Kurt on May 14, 2001 at 04:38:44:
The water pump bolts right on in place of the lower radiator neck (2 bolts I think). Check your generator mounting bolts in case one of them is a different. I don't remember if one uses a stud instead of a bolt, etc. Also replace the upper radiator neck that bolts to the head with 3 bolts as that allows you to mount a thermostat and the sender for a temperature guage.
Stan(VA).
Post A Followup
: Re: Re: Has anyone ever converted a C over to a water pump??
