Re: farmall h 1942 oil
Posted by The Red on May 14, 2001 at 16:01:10 from (12.75.197.249):
In Reply to: farmall h 1942 oil posted by sherri on May 14, 2001 at 15:13:27:
Sherri as CNRed mentioned, the flat belt pulley assembly is lubricated by the transmission. Look at the picture below. Just right of the flat belt pulley assembly you will see a filler tube. That tube is connected to the liftall hydraulic belly pump. The belly pump takes 6 quarts of non-detergent SAE 30. You should see a drain plug on the very bottom of the belly pump.
If you are planning on changing the transmisson/rear end oil, hollar and I will give you some instructions.
Post A Followup
: Re: Re: farmall h 1942 oil
Today's Featured Article - A Cautionary Tale - by Ian Minshull. In the early 1950s my father bought an Allis Chalmers B and I used it for all the row crop work with the mangolds and potatoes, rolling and the haymaking on our farm. The farm and the Allis were sold and I have spent a lifetime working on farms throughout the country. I promised myself that one day I would own an Allis. That time event ... [Read Article]
