Farmall Tractors Discussion Board
Re: Re: Farmall C Timing Marks
Posted by Curt Cooke on February 11, 1999 at 19:34:12:
In Reply to: Re: Farmall C Timing Marks posted by Mey on February 11, 1999 at 07:12:13:
Thanks Guys. That's what I thought but wanted to be sure before I button this thing up. Interesting note, the timing marks on the cam are not a perfect 180 degrees apart. If you mesh single dot to single dot and then rotate, you find the double dots on cam to be 1 tooth off from the single dot on the crank. Thanks again.
Curt
Post a Followup
: Re: Re: Re: Farmall C Timing Marks
