Dang it - Antifreeze in oil what's the culprit?
Posted by Dave G on May 14, 2001 at 19:34:05 from (158.252.165.250):
I got a Farmall B that I get about 1/3 cup of antifreeze out of the oil drain plug and the oil is milky. What is the most likely cause? The guy I bought it from had the head off and I have re-torqued it twice with no change. I hoping it is the head or head gasket - what do you guys think?
Thanks again
Post A Followup
: Re: Dang it - Antifreeze in oil what's the culprit?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
